Re: New pool almost done, several questions
If the plasters are using a high end aggregate plaster and you have not had a lot of hot weather or wind you should be fine. The only thing to watch is that they do not over expose the plaster with the acid, because its harder to expose the plaster the longer you wait. The broken tile is not a big deal if the pool company puts someone experienced on it.
