Thread: Bought a used above ground pool and there is no bottom track??????
    Apr 2012
    Arkansas
    Default Bought a used above ground pool and there is no bottom track??????
    I bought a used above ground pool and during disassembly realized it does not have a bottom track. They had dirt around all sides of it and the upright support posts have a small track on them. They told me it was a penguin brand pool, but I have not found anything about them online. Should this pool have a bottom track? Has anyone heard of penguin pools before? It has a deck that is made for the pool and is incorporated into the construction of the pool.
    Default Re: Bought a used above ground pool and there is no bottom track??????
    Hi ragriffin, and welcome to the forum!!
    I looked around the forum and didn't find much on Penguin pools, but I did find some contact information for them. You might try to contact them at the following:
    1610 SE 47th Street
    Cape Coral, FL 33904
    Phone: (239) 542-3410
    Fax: (239) 542-5598
    General Information Request
    [email protected]
    Maybe they can answer your questions, and if you do indeed need the bottom track, should be able to direct you to where to get it.
  1. bottom drain for 33 round above ground pool
    By kimkats000 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-09-2012, 08:02 PM
  2. There is sand at the bottom of my above ground pool that keeps coming back.
    By confusedpool in forum Pool Equipment & Operations
    Last Post: 06-16-2012, 02:02 PM
  3. Ground By Pool Bottom Ring Wet??
    By poolguy123 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-07-2012, 09:19 PM
  4. Over 1 week after above ground pool installation, AGP 24' round, bottom still soft...
    By ejacoby1 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-10-2011, 11:41 PM
  5. red dust in bottom of my saltwater pool- above ground
    By jandmwallace in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-27-2011, 10:32 AM
