Results 1 to 10 of 13
Thread: Replacing pump motor
    Apr 2012
    Florida
    Default Replacing pump motor
    I have a 1.5hp with service factor of 1.1 and it has started to get loud. I have a 15000 gallon pool with DE filter with solar heating on roof; suction vacuum and SWG. I am in central FL
    I have been researching the Marathon imPower and was wondering if anyone has any experience with this motor.
    It appears it should be a plug in replacement. I am also looking at the energy saving as a factor.
    BB
    Default Re: Replacing pump motor
    Poconos is best with motors. Sounds like a bearing has worn out.
    I'm going to have to get back to this.
    Briefly: the imPower is a variable frequency pump -- driven by electronics -- that has only 3 speeds, and some rather odd behavior. This means, it will NOT do the sorts of things a full VFD pump will, but on the other hand, it doesn't cost a lot more than a electromechanical 2-speed motor.
    One important point to consider: electronics and lightning don't mix well, as a rule. Florida has lots of lightning, and VFD pumps (including the imPower motor) have lots of electronics. Depending on your actual pump make, and your plumbing layout, a better option (more reliable and just as efficient) might be a electro-mechanical hi-E 2-speed motor, with a electro-mechanical timer. The imPower motor may be marginal in your situation, and the description of energy savings appears to make assumptions unlikely to apply to your situation.
    (Generally, the electronic pumps seem to make energy savings claims that are based on a-typical circumstances, or else apples to oranges comparisons.)
    Apr 2012
    Florida
    I agree CarlD that it is most likely a bearing.
    Thanks PoolDoc for your feedback. The guys at a few of the local pool stores say the ImPower is the way to go, but when I ask a few simple questions about the motor none of them can give me a good answer.
    I was considering 2 speed motors before the Impower and the cost different was not that great. But I could not find any review on the Impower (reliability, energy saving etc).
    My pump is a Sta-Rite Dura-Glas with A.O. smith motor with single timer, and my pumping layout is pretty clean 2" PVC the intake side has the drain, vacuum, and skimmer all have 2 way valves that goes to the pump. The pump goes into the filter(DE Hayward 48) and the filter goes to solar and then goes thru the SWG. The solar has an automatic value and an equalizer value. Then back to the pool returns jet, fountain, and two jets all have 2 way valves. When the solar is on the filter pressure increases about 10psi.
    HTML Code:
                filter-----------------|
     SWG-------- |  |                  pump
     |_______    |--|           _______|
       return      solar        intake
    PoolDoc is there any ectro-mechanical hi-E 2-speed motors that you prefer.
    thanks again
    Quote Originally Posted by bbsmith View Post
    Yeah. They want YOU to be one of the people WRITING the reviews . . . and they are hoping they will be good ones. But it sounds like they don't know. (New product designs = unreliable products -- no matter WHO the manufacturer is!)
    As far as 2 speed motors, I've mostly bought them WITH the pumps. The motor-only purchases have been AO Smith, but that was just because that was what I could get.
    mas985's Avatar
    Pleasanton, CA
    AO Smith, now owned by Regal Beloit, is the primary OEM motor supplier for most residential pool pumps so they would be a good replacement. They have recently come out with a high efficiency two speed motor which uses a run capacitor on low speed as well as high speed. They are claiming a 20% improvement on low speed with this new motor. Unfortunately, it only comes in a 56y frame at this point.
    You can find more information here:
    http://www.aosmithmotors.com/WorkAre...mID=2147483754
    Mark
