Results 11 to 20 of 59
Thread: Chemical Help
    Default Re: Chemical Help
    The trichlor pucks are acidic and are driving your pH down. Continue to work on bringing it up. Washing soda will raise pH and alk whereas Borax mainly affects pH. Adding it slowly through the skimmer while the pump is running is the correct way to do it.
    What is your chlorine reading in the evenings when you test (but before you add bleach)? How much chlorine are you losing overnight?
    Go ahead and test the CYA level and report it. You can always buy refills on the CYA testing reagent.
    Apr 2012
    PA
    My CL readings at night are between 1-3ppm, I then add 3-5 gal of bleach, then it is then 5-7 on average with CC 1.5.
    My pH was 6.8 today and TA was 140 the last I checked. So it sounds like I would be better to stay with Borax so I dont get my TA any higher. My jets are aimed at the surface to raise the pH but that has not seemed to work for me.
    Is there anything wrong with adding bleach through the skimmer? I normally add at the return jet in the deep end.
    Oh, do the 3" pucks from Sams club raise CYA?
    Thanks,
    Mike
    22K gal IG 18' x 36' Vinyl Pool, 300 lb Sand Filter, Heat Pump, Taylor 2006, 12 mil solar cover,
  1. Need Chemical Advice
    By vvon66 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-07-2012, 10:36 PM
  2. chemical levels seem ok?
    By GerriLeAnne in forum DPD-FAS based testing
    Last Post: 07-24-2010, 03:12 PM
  3. Chemical Age
    By mohawk in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-19-2008, 09:02 PM
  4. CYA: Chemical OR Organic
    By stma in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2008, 04:44 PM
  5. PH Testing Chemical
    By jrv331 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-26-2008, 08:23 PM
