Re: Chemical Help
New liner installed can go over $1,000 . . . and this is NOT the best time of year to go after one. The pool business has picked up, compared to last year, so the guys that didn't go belly up 2 years ago, are really busy. If you go after a new liner now, you'll be at the bottom of the list, and might not swim till July. Plus, when you pull a liner, there are often OTHER repairs that have to be done.
If you're OK with all that, go for it. Otherwise, keep chlorinating. But, do raise the pH with borax.
Reason: de-sig
