Thread: Low CH
    Apr 2012
    Ohio
    Default Low CH
    I understand by reading on the forum that calcium hardness doesnt matter on an AG vinyl pool, but can really low CH cause any damage to my heater?
    My levels are;
    FC 2.5
    CC 0.5
    TC 3.0
    PH Less than 7.0 (I just finished dropping my ALK and aeration is ongoing)
    TA 90
    CH 80
    CYA 55
    Thanks for youe help
    17,500 Gallon above ground, Hayward 150 pound sand filter containing 75 pounds of Zeobright, 1.0 HP pump, Rheem natural gas heater
    My results are generated from a Taylor K2006 kit.
    27' round 17.5K gal AG pool; Bleach; Hayward 150 pound sand filter; Hayward 1.0 hp pump; 12hrs; Taylor K-2006; well; summer: ; winter: ; iPad; PF:6.9
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Low CH
    no, calcium hardness (actually, the calcium saturation index of which calcium hardness is only one part) only affects how aggressive the water is to plaster surfaces. It does not predict metal corrosion. Low pH is the main water balance parameter that can cause heater damage.
    When lowering TA it is best NOT to drop the pH below 7.0 for this reason and also to protect vinyl liners since you cannot know how much lower than 6.8 or 7.0 the pH actually is with the phenol red pH test used for pools.
    Apr 2012
    Ohio
    Default Re: Low CH
    I just checked and my Ph is back at 7.0. The aeration brings it back pretty quick. I will make no efforts to increase my CH, thanks for the information.
    Default Re: Low CH
    Quote Originally Posted by waterbear View Post
    It does predict metal corrosion. Low pH is the main water balance parameter that can cause heater damage.
    Evan, do you mean it does, or does NOT predict metal corrosion?
    Just for my own info....
    Jan
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Low CH
    Quote Originally Posted by aylad View Post
    Jan
    YES! If you could insert the word NOT in my post above it would be appreciated!
    Default Re: Low CH
    Done!!
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Low CH
    Thanks! I work until late at night and I am just waking up at 9:57 AM when I posted that!
