Results 11 to 15 of 15
Thread: Stair, Vinyl Stain Removal
    Mar 2012
    Default Re: Stair, Vinyl Stain Removal
    Was not sure what thread to use to ask this question since thread the procedure was last edited was closed. I am going to try the ascorbic acid method for stain removal Ben last edited this week. Once you add the sequestering agent (I also did not see the amount to add per 10K gal), how long before you can begin to add chlorine back. Maybe I missed something. Everything else in procedure seemed clear. Wanted to get a feel of how long before swimming can resume -chlorine at minimum per best guess chart. Going to order the materials this weekend from Amazon. Thanks for all the help.
    In-ground rectangle 18x36 vinyl, 26,000 gallons, Hayward super pump, 1/2 HP motor, Hayward Sand Filter, Hayward Navigator Cleaner, Gas Heater (valved off now), county water system same as house, Atlanta, Ga area
    Post this question ON that thread -- I need to make corrections and edits there. Once I see it there, I'll delete it, here. I'm working on those this weekend, so that may work out timely for you.
    Mar 2012
    By "that" thread, are you referring to "http://www.poolforum.com/pf2/showthread.php?7923-Stain-removal-via-ascorbic-acid-treatment"? If so, I didn't see I way I could post the question because it was closed. Sorry for being slow with the threads, but guess I need a little more direction on which thread you want me to post the question on. Be glad to do it once I know where to go. Thanks
    Quote Originally Posted by Cookieman View Post
    My bad -- fixed now.
    -ben
    Mar 2012
    Done. Posted to the other thread. Mbar answered last question, but not sure if final edit had been made.
  1. Vinyl stair repairs
    By austinM in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2013, 06:21 PM
  2. Stain Removal Questions
    By SuitUp in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 09-16-2012, 12:14 PM
  3. Vinyl leak near stair flange
    By davidr in forum In-Ground Pool Construction and Repair
    Last Post: 08-02-2011, 10:28 PM
  4. stain removal
    By poolhelp101 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-03-2009, 01:44 PM
  5. Another use for Cal Hypo - stain removal!
    By Amir in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2006, 12:11 PM
