I have a problem with my pool pump. I recently replaced a bearing and when I assembled it back it does not want to start. It spins freely by hand. Also when I turn it by hand under power it picks up the speed and after few seconds you can hear spring on the governor switch (I guess) and the pump starts to work fine. Also it starts without a problem after shut down until the shaft is still rotating at list a little. When the shaft stops, it does not start again
