Re: Variable Speed pump "sizing" and how do I figure it out
The pool and the spa both have multiple drains in them, I assumed to reduce the entrapment risk. If that's not enough then I guess I'll have to put just a little more priority on this project I am considering.
I dug up the pipe under the "strange contraption" which it turns out is a spring check valve (that must not be closing correctly). Unfortunately, it looks like the underground section of pipe for the spa is also 1.5"
Are the jets themselves something that can be accessed from the spa end of the pipe, or is that something that would require breaking up the decking to access?
