Good catch, Jan. Actually, I think the pH test is accurate with chlorine up to 15 when measured with the K-2006 kit and up to only 5 if using the OTO if I am remembering correctly. But, you are right -- since her CYA is high and thus her shock level will be high, she should raise pH above 7.0 before shocking.
