Results 1 to 10 of 19
Thread: Mixing Sand and Concrete ????
    Default Re: Mixing Sand and Concrete ????
    Just another alternative for the next person, we had to raise the entire area up 6" and so far it appears that it will work well - we used Class 5 fill (also called Class 13 in other areas - used for parking lots, roads - packs and dries HARD) Used a plate compactor x6 times over the area by quadrants - extended 24" out from pool frame with a very slight slope on the edge for drainage, framed by 6" high x 2" thick concrete edgers.
    Aranon is offline Registered+ Thread Analyst Aranon 0
    Thanks all. This is more work than I thought. But its for my three boys so it's got to be worth it. I don't think foot prints would be much of a problem because the 2" foam board is going to go over it. Frost won't be much of a problem because we are just east of Dallas. Hardly ever freezes here at least enough to be much of a heave problem. I will let you know how it turns out. Seem to be so busy at work and the kids functions after work in evenings with schools ending I can't work on it as fast as I want to. Should have the perimeter poured and sand compacted this weekend. Maybe the liner up by Memorial Day. I hope.
    Aranon
