Results 1 to 4 of 4
Thread: Loosing Prime
    Apr 2012
    Connecticut
    Question Loosing Prime
    My pump and DE filter are high above my pool. Every year we have trouble getting everything air tight so we don't loose prim. Does anyone know of a check valve that fits into the inlet of the pool basket strainers so that it closes against the head of the water column (rather than rely on the check valve on the pump inlet)? Thanks, Miguel
    Default Re: Loosing Prime
    Something like this:
    King Brothers Inc. KC-1500-S 1-1/2-Inch Slip PVC Schedule 40 Spring Check Valve, Gray @ Amazon
    may help. (Note that the actual valve will be gray, not white.)
    However, it's hard to find a check valve that won't leak down over time. You'd probably get better results by placing the valve at the BOTTOM of the hill, filling the line between the pump and valve MANUALLY, running the pump till you lose prime, REFILLING, and repeating. That way, you'd 'catch' prime in 2 or 3 'fills'.
    Also, low head pump generally have better suction lift than high head pumps. Not sure what you've got, but the old-school Hayward Super pump is MUCH better at priming than some of the more recent pumps.
    If you send photos to [email protected], we can give more accurate advice.
    Apr 2012
    Connecticut
    Thank you for the tip PoolDoc... I wish smome one made a low profile check valve that could be screwed into the skimmer basket housing bottom connection (for access from above). The skimmer backet depth might need to be compromized a bit but at least that check valve would close with the assistance of the water column above it.
  1. Pump loosing suction
    By tenndoc in forum Pool Equipment & Operations
    Last Post: 09-15-2012, 03:43 PM
  2. Loosing suction
    By Hardley8 in forum Pool Equipment & Operations
    Last Post: 08-01-2012, 01:35 AM
  3. Loosing too much chlorine overnight
    By douge55 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-09-2011, 08:51 AM
  4. can't keep prime in pump
    By PFPAM in forum Pool Equipment & Operations
    Last Post: 06-28-2007, 08:35 PM
  5. Lost prime
    By hunter580 in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 06:22 PM
