Re: Massive algae issues
That's the AO Smith motor number; possibly on a Hayward Power Flo or Power Flo LX. You need to look on the plastic part of the pump, where the pipes connect, for a label with an SP number, like SP1540C
Yeah, it should be OK. I can't find the electrical characteristics on that pump.
You probably need to put a valve between the pump, to throttle flow back some, to keep the motor from overloading. The filter will have so little 'back-pressure' with that pump, that you may create an 'over-flow' situation, which results in overloading the pump.
Do all the piping with 1.5" pipe, and add a 1.5 ball valve between the pump and the filter. You'll need to throttle it a bit during normal operation, but open it wide when backwashing. You should be able to get really, really clear water with that combo.
