Results 11 to 14 of 14
Thread: No questions yet, but sure there will be
    Apr 2012
    Austin, Texas
    Default Re: No questions yet, but sure there will be
    Followed your directions, pool is much better! Thanks!
    Test kit will not be here til next week, so had water tested (sampled at noon)
    Free Chlorine 3.0 ppm
    Combined Chlorine 0.0 ppm
    pH 7.0
    Alkalinity 70 ppm
    Hardness 275 ppm
    Cyanuric Acid 30 ppm
    Cu 0.0 pm; Fe 0.0 ppm; TDS 1000 ppm; phosphates 200 ppb
    inground rectangle pool 17k gal., Hayward DE4820, Polaris 360
    Add a couple of boxes of borax to your skimmer SLOWLY while the pump is running. Other than that you're fine. . . if those tests are accurate.
    Apr 2012
    Austin, Texas
    Pool is looking MUCH better. Will be Thursday before test kit gets here
    . . . just make sure to maintain your chlorine levels.
  1. New Pool Owner Questions - 8 questions!! :)
    By kmmlangston in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2010, 05:33 PM
