Replacing pool bulbs can be very tricky. The bulb may be standard, but the lamps are not. You need to make sure you know the type of lamp, and that you have replacement gaskets available BEFORE you try to remove the lamp. Otherwise, wait till you don't mind if the pool is unusable for 2 weeks, because you've got a messed lamp and wires in the water.
