Re: Test Results - Please Review
I'm not really an expert, but to this amateur they look OK. I'm sure Pooldoc will chime in.
They like the TA to be a little higher so you might look at that. You said you've got an above ground so I assume it's a vinyl liner and I don't think CH is too important with a vinyl liner.
If it were me I would get the chlorine up, it's easier to stop an algae outbreak than it is to fix the aftermath. Just be careful on how you apply the chlorine, you don't want to bleach your liner out.
I would listen to Pooldoc or one of the other experts, I'm still at "dangerous bystander" phase LOL.
Good luck.
~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
