Any idea when you'll get the kit? We really need to know a CYA level. Keep you chlorine up, run the pump 24/7. Is your filter pressure rising? Backwash whenever it rises 8-10 psi over clean filter pressure.
If it truly is a 50lb filter, you're not kidding that you have a huge equipment mismatch! It may take a LONG time for your pool to clear.
I'm gonna ask Ben to pop back in here and advise you again. Especially with such a big equipment mismatch.
