Thread: need help reading cya results from K-2006 test kit
    Kateyru is offline Subscriber Thread Analyst Kateyru 0
    Apr 2012
    Alabama
    Default need help reading cya results from K-2006 test kit
    I think I may not be reading the cya results correctly. Instructions on K-2006 test kit say "Slowly transfer cloudy solution to small comparator tube until black dot on bottom just disappears when viewed from top." I thought that meant that I should not see the dot at all but my results are always 30. What am I looking for, when the black dot begins to turn gray? I'm using reagent way too fast this way...
    Thanks!
    16'x30' rectangle 22K gal IG vinyl pool; SWCG; Hayward Pro SEries S220T sand filter; Hayward pump; hrs; Taylor K-2006 ; city; PF:5.5
    Largo, Florida
    Default Re: need help reading cya results from K-2006 test kit
    Quote Originally Posted by Kateyru View Post
    Thanks!
    The dot has to completely disappear. They don't give you very much CYA reagent, only enough for like 4 or so tests or something like that. You can order the CYA reagent in a large bottle and refill the small one for not TOO much money (around $15 with shipping).
    Here's a link:
    Taylor R-0013-E
    Apr 2012
    Alabama
    Thanks for the response and the link!
