Thread: should the sight glass on filter be cloudy
    mississippi
    Default should the sight glass on filter be cloudy
    when I rinse my filter the water spinning in the sight glass is cloudy just like my water. what does this indicate? problem with filter, not backwashing enough?? my water is still cloudy and I am problem solving all over the forum, but thought I would mention this here.
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Default Re: should the sight glass on filter be cloudy
    I'm assuming you're rinsing immediately after backwashing but before you start running the filter again in "filter" mode. If you're backwashing thoroughly, the rinse water should be clear (possibly cloudy for a second or two, but not after that). If it's running cloudy for longer than that, I'd suggest backwashing for a longer amount of time.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
