Thread: Should I be testing and adjusting even when pool is covered?
    Lincolnton, NC
    Default Should I be testing and adjusting even when pool is covered?
    I guess the heading says it all. I have not tested or added chems since I closed it up in early November.
    Also, how do I figure the volume of my pool. Thanks
    duraleigh Guest
    Default
    I would at least run my tests so I would know in advance what I'm going to need once I pull the cover back.
    Figure how many cubic feet you have in you pool X 7.48 = gallons
    Lenny is offline Lifetime Member Thread Analyst Lenny 0
    Wilmington, Delaware
    Default
    duraleigh,
    If you pull back the cover and grab a test sample without mixing the water, would you expect that to be a representative sample of the entire pool?
    My first sample this year, before I took off the cover and circulated everything, seemed to be a mess. I was just learning to use my test kit but I'm pretty sure it was a bad sample.
    duraleigh Guest
    Default
    Quote Originally Posted by Lenny
    duraleigh,
    Hi, Lenny,
    Yeah, you've probably got a good point. It may not be very accurate. However, I'd think you could stir it with a submersible pump or, in a pinch, a long stick and you'd get close enough to make it meaningful.
    When I first started with my kit (Ben's), I screwed up some tests and didn't understand how to do one of them. This forum will help you out if you get stuck.
    Dave S.
    Default
    When the winter cover's on, I don't test. Period.
    I take the cover off, first, connect and fire up the pump and filter, and get it circulating. THEN I'll do my first testing.
    Before I close I add 1 quart of Polyquat, wait 48 hours, then run the FC up to 15 and close. Then I leave it until spring unless I have to syphon off some water to prevent overflowing.
