Thread: Main drain pain
    Rock Tavern, NY
    Default Main drain pain
    When the guy replaced our 2 return lines, in-wall vac line & valves, he bypassed my main drain. I had told him earlier in the day that a diver had determmined there was a slight leak last year and had plugged it with a main drain winter plug. When the guy was done with my lines, I realized he had bypassed the main drain. He said since it was leaking and now plugged, I shouldn't be bothered with it. I am a little irritated by this. Was there a better solution than him taking it upon himself to do this? I told him I want him back to replace it (and at the same time have him install a multi-port valve, which our system has never had. Who's right? What are my - and his - options?
    18x42 Spartan Roman End Vinyl Inground (1981)
    1HP Hayward Superpump -- Hayward Perflex EC-65 DE Filter
    salinda is offline Lifetime Member Weir Watcher salinda 0
    San Jose, CA
    Default Re: Main drain pain
    I don't know what's right, but you could install a suction-side cleaner as an option. It is like a roving main drain....
    Salinda
    Orlando, Florida, USA.
    The one who is right depends on what was discussed and promissed regarding the repair. I have a main drain which I never use. I prefer to run the skimmer at 100% since my pool is not covered. I also have a suction side clean to get the bottom clean - which also helps circulate the deep water.
