Results 11 to 12 of 12
Thread: Why Does My DE Filter Lose Pressure
    Jul 2013
    Northern Illinois
    Default Re: Why Does My DE Filter Lose Pressure
    How is it going?
    Baltimore, MD
    turns out it must have just been a dirty pool. Pressure seems to hold steady at 20psi now. Lesson learned here though is that a dirty pool may require a backwash every 2 hours or so. Seems to be pretty normal.
    48x14 rectangle in-ground concrete pool, 29k gallons, Taylor K-2006, 8.25% Clorox
    DE Filter Pentair FNS Plus FNSP60 (filter area – 60 sq ft, GPM 150, diameter 21.5”, turnover capacity 86,400 per 12 hours)
    Pump 1HP Pentair WhisperFlo high performance
    SWCG Zodiak LM3-24 (24 grams of pure chlorine per hour)
    Booster Pump Polaris Halcyon PB4-60Q
    "No pool store junk goes in my pool"
  1. Do tri-chlor tabs lose potency?
    By TomC in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-31-2012, 09:05 PM
  2. Low pressure in filter?
    By mkelley in forum Pool Equipment & Operations
    Last Post: 07-13-2008, 06:30 PM
  3. How many PPM of Chlorine should I lose daily?
    By keithw in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-10-2006, 06:06 PM
  4. Filter Pressure Q - is this too low?
    By rrands in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 11:31 PM
  5. Suction Leak Causes Pump to Lose Prime
    By donjoarm in forum Pool Equipment & Operations
    Last Post: 04-14-2006, 12:00 PM
