Re: Why Does My DE Filter Lose Pressure
First, thank you for taking the time to help me. You are correct, I"m using a red 16oz cup. I've already ordered a DE Scoop cup last night. For now, is there an easy to way to figure out how much DE i need using my plastic cup?
Also, how do I run the pump on high speed? I know there are main drains and skimmer drains. I do have 2 pipes coming into my pump and 2 going back out. But they are not labeled. I assume I need to shut off the main drain and do only skimmer and that would run my pump on high speed? I'm trying to insert a pic but I can't figure out how.
48x14 rectangle in-ground concrete pool, 29k gallons, Taylor K-2006, 8.25% Clorox
DE Filter Pentair FNS Plus FNSP60 (filter area – 60 sq ft, GPM 150, diameter 21.5”, turnover capacity 86,400 per 12 hours)
Pump 1HP Pentair WhisperFlo high performance
SWCG Zodiak LM3-24 (24 grams of pure chlorine per hour)
Booster Pump Polaris Halcyon PB4-60Q
"No pool store junk goes in my pool"
