Thread: Bubbles in return lines
    Scottsdale, Arizona
    Default Re: Bubbles in return lines
    email sent ... I told him to send you the bill
    Scottsdale, Arizona
    So, how long can a pump run dry before it destroys its self?
    My timer comes on at 7 am and I would assume it would only take about 10-15 minutes to pump it down to the point that the skimmer was dry and start sucking air so it could have run dry for an hour.
    What symptoms would it display that there has been damage done (other than the obvious bearing noises etc...) ?
    Scottsdale, Arizona
    Rebuild kit just showed up on the Big Brown Truck... Slapped it together and installed. I'm generating chlorine again, the bubbles are gone (only ran for a few minutes, will confirm when the run cycle kicks in tomorrow) and the pump appears to be undamaged.
    I still think I need to mount the cell vertical so if we can get the pics up, I'll look for opinions on adding the number of 90* angles it would take to do so... I'm thinking 4.
  1. Air Bubbles in Return Lines
    By dnspade in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2011, 03:05 PM
  2. Air bubbles in return lines, found & fixed problem
    By bcb1 in forum In-Ground Pool Construction and Repair
    Last Post: 06-14-2007, 11:38 AM
  3. Bubbles from return
    By spcchap in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-25-2007, 07:52 PM
  4. Air in Return lines
    By berardi17 in forum In-Ground Pool Construction and Repair
    Last Post: 07-02-2006, 05:51 PM
  5. Air Bubbles in Return
    By rrands in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 11:33 PM
