Thread: Another Problem!
    Jan 2012
    Default Another Problem!
    Well, just confirmed another problem caused by the local pool company that built my pool.
    The umbrella sleeve in the sun shelf was capped with what appears to be a return jet orifice...meaning it has an approx. 3/4"diameter opening as opposed to a typical 1.5" diameter opening for standard umbrellas.
    What are my options???
    Please don't suggest that my pool company fix the problem...I would prefer to have a non-functioning unusable umbrella sleeve than to let them back on my property.
    The orifice on the sleeve is very firmly arttached...not sure what I would do to the shelf and surrounding PebbleTec if I tried to pry it off.
    Thanks for any advice.
    Scottsdale, Arizona
    Default Re: Another Problem!
    Can you find a way to step the umbrella pole down to 3/4" ? Maybe a long piece of PVC that you insert inside the umbrella pole?
    PVC won't work and would break, but a length of 3/4 steel pressure pipe may. Home Depot sells it.
    Cheap fix, too.
    vinper is offline Subscriber Thread Analyst vinper 0
    Texas
    It Should screw off ,, I dont think they would have glued it on . If so cut or grid it off flush rout out the inside .. You will have to lower the water level
  1. Please help...never had this problem before
    By Mattcef in forum Dealing with Algae & Slime
    Last Post: 06-19-2012, 08:36 PM
  2. Algae problem or fliter problem ?
    By ROBIN13 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-14-2006, 03:29 PM
  3. PH and TA problem
    By aguaguy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-27-2006, 03:46 PM
  4. PH problem. Help.
    By bookworm in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-18-2006, 09:18 PM
  5. New Problem...
    By Dafreak in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2006, 10:05 AM
