Thread: External timer
    May 2012
    South Florida
    Default External timer
    My first post has to be here, so please excuse me if this question has been answered before.
    I have a Dig 220, just installed the relay as per the instructions. I have triple checked the wire configuration.
    My unit still says external timer. I do hear a click when I hit boost, but cannot get my pump to come on. I do see program 1 occasionally in the screen, but cannot get it to program.
    How do I get it out of 'external timer' and program mysingle stage pump. BTW, it is set up for 220 and I did check the board to make sure the jumper was in place for 220.
    Edited to add.... OK, so I found the answer. The manual says to hold the menu button for 13 (thirteen) seconds, not 1-3. Now if I can just solve my priming problem that just started ... LOL.
    This is my second SWG, the first one lasted me almost 8 years and was mostly problem free..
    Any thoughts or ideas would be most appreciated.
    Thank you in advance for any input.
    May 2010
    Default Re: External timer
    Hi Medic and welcome to the Forum. Glad to hear that you found and fixed your problem with your unit. Can you describe your priming problem in more detail?
    Ft Lauderdale, Fl
    Please feel free to contact me directly if you have any specific questions on your DIG-220.
    Sean Assam
  1. Problem with Timer?
    By s2mobile in forum Pool Equipment & Operations
    Last Post: 06-02-2010, 01:43 PM
  2. Timer
    By jrv331 in forum Pool Equipment & Operations
    Last Post: 06-11-2007, 02:04 PM
  3. External Pool Spot Lights - High Voltage or Low Voltage?
    By CJDahl in forum In-Ground Pool Construction and Repair
    Last Post: 01-16-2007, 10:31 PM
  4. Timer question
    By CanuckPool in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-07-2006, 08:38 PM
  5. First Timer
    By Pinman24 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-05-2006, 12:23 AM
