Thread: It rained so much, the pool level was even with my deck
    Jul 2011
    Boca Raton, FL
    Default It rained so much, the pool level was even with my deck
    About a week ago, we had so much rain in So. Florida that my pool was over-filled to the point where the pool water level was literally even with my deck. I have heard it said -- long ago, before I was a pool owner -- that you shouldn't allow your pool to overflow like that. I'm guessing it's because it is damaging to the pool in one way or another.
    When a big rain is about to come (think: hurricane season in Florida), is it okay to just let the pool fill-up to the brim like that? Or is there some reason to keep the water level below the coping?
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
    mas985's Avatar
    Pleasanton, CA
    Default Re: It rained so much, the pool level was even with my deck
    Personally, I think most of that is a myth. When pools overflow, it is no different than runoff from a deck or driveway with the same surface area. There is water anyway from the rain. The biggest issue is that the skimmers will not work well when the level is too high.
    Mark
    Just guessing here, but it seems like a greater chance of getting water behind the liner if the level in the pool rises over the coping.
  1. Brass deck jets versus Jandy deck jets
    By pumpkineater59 in forum Pool Equipment & Operations
    Last Post: 04-13-2012, 12:58 AM
  2. in deck or on deck slide and diving board
    By bszaronos in forum Pool Equipment & Operations
    Last Post: 03-16-2012, 12:52 AM
  3. CYA level and chlorine level and pool store recomendation
    By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 11:25 AM
  4. Please Help! Rained while pouring concrete
    By rachunter in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-17-2010, 05:32 PM
  5. moss on a carpet covered deck (factory pool deck)
    By JETTA in forum Above-Ground Pool Construction & Repair
    Last Post: 09-08-2006, 08:56 PM
