Skimmer Problems
My skimmer basket seems to have lost resistance - usually I cannot remove the skimmer basket while the pump is running. It now just lifts right out.
It was working fine until a couple of days ago and I am at a loss as to what is causing this.
Pump basket is clear of debris. Have put my hand in and turned the impeller it moves freely doesn't appear to be clogged.
Have put a plastic bag into skimmer and it went straight to the pump basket with no problem.
Sand was replaced coming up for 3 years ago.
My filtration system has been running continuously as I have been clearing a really nasty algae outbreak.
Pump usually starts at 10 and rises as and when it needs back washing. Have had to do a lot of back washing while trying to clear the algae up.
Water is very cloudy and doesn't seem to be clearing.
Any suggestions as to what the problem can be?
- You may not post replies
- You may not edit your posts
Forum Rules
