I'd clear up the pool and then add CYA if it were my pool. If your pump/filter are not yet running, you're not really going to be able to get it dissolved and into the water.
Glad to see you back around the forum for another season!
Thanks. Got the filter going now, FC is holding....I'll vacuum up and then add cya
20,000 gal IG plaster, Hayward Super Pump, EC65 DE filter.
I have diclor. Will that help raise my cya? I have a 22,000 gallon in ground vinyl lined pool and my cya is at 0. Everything else is good. If I cant use the diclor what should I use and how much do I need to add?
You can use dichlor since it does have CYA in it, but it will take some time for your CYA level to increase. After you get the CYA level up to around 50 or so, you'll want to discontinue dichlor and only use bleach or liquid chlorine.
Now -- before you put the dichlor in, give us the package ingredients. Some places sell dichlor that is blended with some stuff that you do NOT want to be put into your pool. Also give us the Brand and product name.
Brand is Aqua Zone
Ingredients
Sodium dichioao-S triazinetrione hydrate......... 99%
other ingredience(thats exatly what it says).....1%
Available chlorine.......................................... ..55.5%
If I can use it how much and how offten do I test?
THANKS!
sorry spelled dichioao-S wrong should be dichioro-S
oh and my chlorine is at 10 ppm. Since it is in a good range I really don't need to add any so what should I use to raise my cya? Last year was my first year using the BBB method, trying to clean up a big mess the pool store made of my pool and it was at 70 so I didn't have to add. The last thing I want to do is ask the pool store for a stabilizer and end up back where I started.
You can just buy some CYA and add it outright instead of using dichlor if you want. You may have to buy it from a pool store, but just don't buy anything else while you are there. You might find it at Walmart or someplace. It might be called stabilizer or conditioner but if the ingredients say cyanuric or isocyanuric acid, it is the right stuff. Add enough per package directions to get to about 40 or so. Add it slowly to the skimmer while the pump is running and then do not back wash your filter for at least a week and run the pump 24/7 for four or five days while it is dissolving.
Another option is to just use the dichlor that you have on hand to add the CYA as you chlorinate. Though your chlorine level was 10ppm when you tested, it isn't going to stay there if you currently have no CYA in your water. So, as you need to add more chlorine, your dichlor will gradually be adding CYA. Monitor your CYA level every couple of weeks and when you get to 50ppm, switch to either bleach or liquid chlorine.
A third option is to add some CYA now to get to a reading of about 25 or 30 and then to use dichlor for awhile to get the rest of the way up to about 50.
The dichlor will add 9 ppm CYA for every 10 ppm FC so if you are tryng to clear a green pool dichlor is a good choice since it dissolves (and therefore adds CYA) very quickly! You don't really have to wait for the CYA level to come up. It is there as soon as the dichlor dissolves (which is usually before it can hit the bottom of the pool when broadcast on the surface of the water.) Just shock with the dichlor until the pool is not longer green. If you have no CYA in the water your 10 ppm FC wion't last long and if you are still clearing the pool it won't last long either!
Dichlor is going to get CYA in the water much faster than adding CYA so if you need some in the water fast (and also since you have the dichlor on hand) I would suggest using it.
In a 22000 gal pool each pound of dichlor will raise your FC by 3 ppm so using 10 lbs total over time will get the CYA to just under 30 ppm (27 ppm to be exact). 11 lbs of dichlor will get raise the CYA 30 ppm so by using a total of 11 lbs to chlorinate and shock with instead of any other chlorine sources will get your CYA up pretty quick.
