Re: Pool Help/Advice for new pool owner
Are you recommending to drain my pool all the way? This was my original idea, but i am not sure if I can do it. I live less than 1 mile from the bay. I think I might be to close to the water column. I will be digging a hole today, to see if I will reach the column or not. If I hit water, it is my understanding that if I drain, it could collapse the gunite? Is this correct?
If I drain, I need to pipe the water about 200 yards, to a nearby sewer head. Have any suggestions on where to get a pipe of that size?
2. You suggest to add the dichlor to add free chlorine and stabilizer. What levels do i want my pool at? How do i calculate to get the ppm? Is this what the test is for? Is that the ratio of chemical to 1 million gallons? How much would you start with? i have a 7k gallon pool?
If I cannot drain my pool all the way down and start over, how would you do it?
Again, thanks for the help.
In Ground, 6,900 Gallon Gunite pool with tile trim, Haywayd EcoStar SP34000VSP Variable Speed, Aquarite 25k SWCG, North Florida
