I wouldn't be too quick to fall all over this guy. Remember the "Cyanurics:Benefactor or Bomb" article? He's directly cited that article as the source for his thinking.Originally Posted by CarlD
I found Ben's response to that article:
http://www.poolforum.com/pf2/showthread.php?t=756
Also, I'd be somewhat concerned keeping low levels of Cl in the pool, because of his belief that you "don't need much". Sure you don't, if nobody uses the pool. You have to have some Cl reserve in there. Coupling bather load + sun = a rather scary possiblity of swimming in a non-sanitized pool.
Personally, a SWC takes care of all my needs with virtually zero maintenance. I know it's safe, and I know it works. Bleach works equally well, it just takes a little more maintenance to keep your levels up. I had considered a pressurized Cl feed at one point, but decided the negatives far outweighed the positives.
Michael
