Hi Ann;
1. Do NOT trust the pool calculator website on pH effects -- the pH calculations are often wrong, in ways that are difficult for me to explain.
2. Stick to the 2 boxes and test -- that will work.
3. The K-2006 will not test lower pH levels, but if you want to, you can do the "acid demand" test, which will allow us to determine if you are a little below 6.8, or a lot.
4. Unless you want your "cloudy blue" pool to turn "cloudy green" do NOT stop adding bleach daily. If it turns green, recovery will be MUCH harder!
5. If borax is not available, dose with ONE box of Washing soda at a time (instead of two boxes of borax).
You need to learn to distrust the pool store more . . . or you'll end up a victim again.
