Results 11 to 12 of 12
Thread: cooling the pool in Phoenix
    May 2010
    Default Re: cooling the pool in Phoenix
    Aylad is correct. You will not reduce the water temp any appreciable amount that would require a change in your water chemistry. You will still need to do the normal chemical basics.
    May 2012
    Phoenix, AZ
    Hi,
    Understood that there's no magic bullet here. Still need to test and adjust regularly.
    I was reading the "Pool Tips" over on poolsolutions.com. Tip #6 says to add chlorine in the evening instead of the morning, since "During the day, it mostly is wasted -- lost to UV in the sunlight." Using this logic, I would think that some shade would help. Maybe I'm splitting hairs here?
    Thanks,
    hikernut
  1. Pool cooling in muggy se missouri
    By Majesticman in forum Pool Equipment & Operations
    Last Post: 08-11-2011, 11:54 PM
  2. Pool water cooling
    By mshumack in forum Pool Equipment & Operations
    Last Post: 08-22-2010, 12:18 AM
  3. Phoenix Super Erase
    By TwistyKat in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-11-2008, 03:42 PM
  4. Does anyone know an AutoPilot Installer in the Phoenix area?
    By slater1182 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-20-2008, 11:28 AM
  5. Cooling a Hot Pool
    By [email protected] in forum Pool Equipment & Operations
    Last Post: 09-03-2007, 01:26 PM
