Thread: Using Intex Salt System with larger pool
    May 2012
    Disputanta, VA
    Default Using Intex Salt System with larger pool
    Hi all, first post. Soon to be new owner of 15 x 30 Martix above ground pool. Have the ground level and ready to set up if it will quit raining here in Virginia. My question is, can I use a intex salt system with this size pool? We are moving up in size a little and according to manuel it will make clorine for up to 14,000 gals. It's Intex model 10CS 8110 that was purchased in May of 2011.
    Thanks!!
    Eddie
    Default Re: Using Intex Salt System with larger pool
    You probably could, though hooking it up might be a trick. The issue you may want to consider is that using an SWCG will void the warranty on most conventional AG pools. So, you might want to wait a year.
    May 2012
    Disputanta, VA
    Thanks for the reply. Other than the liner, which part of the warranty could it void. We used the salt system for 4 years with Intex pool with no issues.
    Thanks!!
    Eddie
    Most standard AG pools have metal walls &/or coping that is in intermittent contact with pool water. When it dries, it leaves the salt behind, where it can accumulate, especially in dry areas.
