Thread: Clear water but dark algae
    Default Re: Clear water but dark algae
    Quote Originally Posted by cscgal View Post
    They recommend either empty half of pool or use muractic acid and shock that does not have stablizer in it..... So, so far I have use 2 gallons of muractic acid and just started a weekly maintenance of shock with no stablizer in it.
    Huh? Your pool store told you to use 2 gallons of muriatic acid for what? To lower the CYA? That's a first. I don't think we've heard that one before!
    We really are going to need some good testing numbers to be able to help you much. If you haven't ordered the Taylor K-2006 kit like Janet suggested above, you should.
    Yeah, and I'd run away from that store as fast as I could.....
