Re: DE out the jets...
Thanks, I broke it apart and figured out THAT problem - didn't have the manifold seated correctly. My problem NOW is I'm getting 30psi off the filter :/ Backwashed several times, water coming off is clear, but the pressure only stays low (at low pressure the pool jets blow nicely, high pressure they're barely a dribble) for about 30mins, then right back up to 30.
