Thread: CYA question
    Jul 2011
    Wantagh
    Default CYA question
    Opened the pool 5 day's ago followed the advice given by pool doc and I now have a very clean pool. Now besides warming up the water my CH,PH are good the TA is a little low @ 40ppm and I have no CYA. My pool end's up with too much CYA towards the end of the season, now that it's been shocked with bleach and no green at all if I switch to Trichlor puck's will I get the CYA I need or should I add stabilizer? Thanks for all your help you made my life a lot easier.
    inground rectangular pool 16' x 36' 8' deep end 26,000 gallons black vinyl liner
    Default Re: CYA question
    Ifyou use trichlor, the CYA will rise, which is probably why you've had high CYA problems in the past. However, it mght not rise fast enough. If you find this to be true, you could add straight CYA to about 20 ppm for a "loading dose", then switch to trichlor for awhile until you reach your target.
  1. Spring Vacuum Question and Liner Question
    By DougM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2011, 12:11 AM
