Ifyou use trichlor, the CYA will rise, which is probably why you've had high CYA problems in the past. However, it mght not rise fast enough. If you find this to be true, you could add straight CYA to about 20 ppm for a "loading dose", then switch to trichlor for awhile until you reach your target.
