Thread: upgrade options for pump/filter....
    Jun 2011
    Oklahoma
    Default upgrade options for pump/filter....
    I am looking for suggestions in uprading my pump/filter. I have the original pump/filter that came with the pool. My pool info as well as pump/filter info should be in my signature.
    20' x 48" Intex round Ultra AGP ~8800 gallons -- Intex krystal clear 635t 1500gph; PF: 13
    Howell NJ
    Default Re: upgrade options for pump/filter....
    Hi. Not sure what pump and filter you have by your signature. I think if you post what you actually have the folks here can help you better.
    If you look around the site here, you will see the consensus is a large sand filter coupled with a two speed pump. Cleans well and saves electric.
    Hope this helps.
    Mike NJ
    12x18 vinyl AG 6.2K gal; Hayward equp: 16" sand filter (spring clean up) -- Xtream 100 sft cart (after clean up) -- Power Flo Matrix 1hp 2spd pump w/ AO Smith motor
    Jun 2011
    Oklahoma
    The pump/filter I have is the original that came with the pool. Intex krystal clear 635t 1500gph(which i assume stands for gallons per hour). I dont really know anything else about it. There was no horsepower ratings listed.
