Closed Thread
Thread: Intermatic T104 timer and Goldline GL-235 wiring help for bypass mode
    May 2012
    CA
    Default Intermatic T104 timer and Goldline GL-235 wiring help for bypass mode
    Hello,
    Can someone please help me in wiring up my GL-235 so that the bypass feature will work in freezing weather.
    This is the wiring diagram for the GL-235 controller
    See page 7 figure 3 for Goldline GL-235 wiring diagram
    http://www.sunvoltenergy.net/BodyPag...n%20Manual.pdf
    On the GL 235 there are 6 poles
    #1 - Ground | #2 - 240 line 1 | #3 - 240 Line 2 | #4 - 120 Line | #5 - To filter (left side of timer) | #6 - to filter (right side) of timer
    T104
    Poles 1 and 3 are 240 source and poles 2 and 4 go to pump motor.
    I can figure out power - connect t104 pole 1 to pole 2 on GL-235 and pole 3 to pole 3 on GL 235.
    I don't understand how to wire up poles 5 and 6 on the GL-235 to the T104 controller so that it can auto start pump when it detects freezing weather.
    Any help would be appreciated.
    Thank You
    Default Re: Intermatic T104 timer and Goldline GL-235 wiring help for bypass mode
    Quote Originally Posted by netprotex View Post
    Can someone please help me in wiring up my GL-235 so that the bypass feature will work in freezing weather?
    The answer to your question is -- as a matter of policy -- No!
    The reason is simple: electricity and pools mix fatally, in the event of a mistake. We sometimes answer questions about equipment but I do NOT allow answers to "how can I wire this . . . ?", except in general terms. Again, as a matter of policy, my position is, if you have to ask, you shouldn't be doing the wiring.
    This is not a theoretical danger. I've twice been nearly killed myself, by amateur pool wiring. One of the 'amateurs' was a Southern Railways signals engineer! And once, we nearly killed a life guard with a pool vacuum WE built, when the guard did something stupid (which we should have anticipated!) and the GFCI failed 'ON' rather than 'OFF'.
    Sorry. Thread chlosed.
Closed Thread
  1. Intermatic PE24VA to replace Goldline actuator
    By Geeper in forum Pool Equipment & Operations
    Last Post: 08-23-2011, 04:42 PM
  2. Intermatic Timer.
    By Phillbo in forum In-Ground Pool Construction and Repair
    Last Post: 04-05-2009, 04:18 PM
  3. anyone have time trippers from intermatic timer they will sell to me?
    By tenax in forum Pool Equipment & Operations
    Last Post: 07-05-2006, 08:26 PM
  4. Intermatic timer trippers
    By ScottS in forum Pool Equipment & Operations
    Last Post: 06-07-2006, 12:28 PM
