Thread: Amount of borax to use to raise pH
    May 2012
    Kansas, USA
    Default Amount of borax to use to raise pH
    We have an above ground pool, 5,000 gal. Needing to know how much to add and how much raise. Also how long after adding to test.
    Default Re: Amount of borax to use to raise pH
    Given that we know NOTHING about your pool, 1/4 of a box, added SLOWLY to the skimmer is a reasonable dose. Again, better info depends on specifics you haven't provided, but in general pH levels above 7.0 and below 8.0 may be acceptable.
    If you don't have a kit, you need to look at the kit info page in my signature.
