Results 1 to 9 of 9
Thread: Does anyone use the The Pool Blaster Max (HD or CG)?
    May 2012
    Orlando, FL
    Default Does anyone use the The Pool Blaster Max (HD or CG)?
    The Pool Blaster Max is a battery powered spot cleaner that mounts on the end of a telepole. Sort of like an underwater dust buster. I like the idea of spot cleaning without having to drag the suction cleaner hose out and run the pool pump. This would be really useful to pickup a leaf on the bottom or clean the sun shelf where my automatic (suction-side) cleaner won't go.
    I my research it sounds like (to some) this device only lasts a year or so before water gets inside it runins the battey or motor. Then a repair is almost as expensive as the device costs. I know most user reviews are done when the user is either very happy with their purchase (new user) or the device turns out to be crap.
    So, I asking here, does anyone use this thing, does it work, will it last at least a couple of seasons, and/or is there something else/better available.
    Thanks for your time and response(s).
    Default Re: Does anyone use the The Pool Blaster Max (HD or CG)?
    There are some previous posts around the forum on this question--you might want to use the google search function in my sig to look around for them...one of the other mods, CarlD, had that same problem, and ended up changing his battery out a couple of times over 2 or 3 seasons. I personally have one, and it's still working fine on the original battery. I got mine about 4 years ago and have been very, very pleased, although I think mine was one of the original Pool Busters--the HD and CG are updated models of the one I have.
    May 2012
    Orlando, FL
    Okay. Your experience is good enough for me. I'm going to get one.
    BTW - on the search feature how do you string a couple of words together? Is is something like Pool+Blaster or "Pool Blaster" (with the quotes). Neither seemed to work right. I got everything with "pool" in it.
    Try running the words together... i.e. "poolblaster" and see if that doesn't help.
    Apr 2012
    Texas
    CountryBumkin, please let us know how you like the pool blaster max when you get a chance to use it. I am thinking of making that purchase myself...
    For those that already have one, does something like this clean up fine particles like dust/dirt or no?
    18' round 7.5K gal AG vinyl pool; bleach; Hayward C900 cartridge filter; Hayward Power Flo Matrix 3/4HP pump; hrs; HTH 6-way test kit
    ; community; PF:16
