Thread: Saltwater
    May 2012
    Texas
    Default Saltwater
    I have an inground pool with a vinyl liner. I continually have a high cyanuric acid level. I use Sam's Club chlorine granuals and think that may be the problem. If I change to the salt water system will this solve the high cyanuric acid level problem?
    Rick
    Default Re: Saltwater
    Hi Rick, and welcome to the forum!
    High CYA and salt systems really don't have anything to do with each other, except that IF you have a salt system, you also have to have a high CYA to make the salt cell work at its highest efficiency.
    If the chlorine granules that you are using are dichlor, then yes, that's what's causing your high CYA. At this point you have a few options:
    1) Switch to a SWCG system that will require you to have around 80 ppm CYA, and it will use the salt to generate your chlorine, eliminating the need for you to have to manually chlorinate the pool, or
    2) Drain some water and refill with fresh in order to lower that CYA level, then stop using stabilized chlorine and switch to Cal-hypo or bleach, or
    3) Simply raise your chlorine levels to compensate for the high CYA, which is probably your best (and definitely your cheapest) alternative, especially in Texas. Check out the link to the "best guess chlorine chart" in my sig for more information there.
    Regardless of the route you choose, you DO need to stop using the stabilized chlorine, if you don't want your CYA to go any higher. Once it's in the water, it's there--the only ways to lower it are through splashout, water drain, or letting it go swamplike (which has a whole 'nother set of consequences, so I wouldn't even consider that one.).
    May 2010
    I was in the same boat a few years ago. My CYA was off the chart due to years of use of 3" tablets. I drained 2/3 of my water and re-filled only to find I still had high CYA. Aylad is right, Switching to Salt won't help you. Complete draining is in all probability the simplest solution. I was also told that the CYA will also impermeate the liner as well, but I am not completely sure of this. Please tell us what your actual CYA reading is.
