Thread: gunite stains
    May 2012
    MD
    Default gunite stains
    we have a SWG pool that was installed in 84. The finish isn't smooth the previous owner said they had it acid washed once. there is a orange-brown stain on the walls and sides of the pool that we are trying to get rid off. scrubbed it last year with vitamin-C, pumice, clorox tablets and were unable to remove the stain.
    I have drained the pool and an getting ready to scrub the pool. Question is whether we should use water/soap/bleach mixture or muriatic acid.
    Or is there a better way to proceed?
    regards,
    andy
    Default Re: gunite stains
    Acid washing destroys pool surface, removing the stain, but leaving the plaster rougher, thinner, more porous, and thus more susceptible to stains!
    Try using Iron Out -- you can get a bottle at Walmart in the detergent section -- and see if that helps. If Iron Out doesn't remove, or at least lighten it, it's probably NOT a metal stain.
    If Iron Out does work, you may want to get a larger quantity from Amazon:
    Super Iron Out IO30N Rust Stain Remover, 30 oz
    Super Iron Out IO65N Rust Stain Remover, 65 oz
    The larger size ships from Amazon, so if you get the 1 month Amazon Prime trial, you can have it shipped 2-day for no extra charge.
  1. Stains on bottom of gunite pool?
    By Shipper in forum --cleanup--
    Last Post: 05-26-2013, 01:26 PM
  2. Freaking OUT! Brown stains on my gunite pool!
    By dblomom in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-20-2012, 06:16 PM
  3. Rust Stains on Bottom of Gunite Pool
    By kc101 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 03-16-2012, 10:37 AM
  4. acorn stains in new gunite pool
    By beary in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 09-25-2006, 12:23 AM
  5. Algae or Stains in my gunite pool
    By rwkelleyjr in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-07-2006, 11:56 PM
