Results 1 to 10 of 15
Thread: new pump?
    Apr 2012
    New Jersey, USA
    Default new pump?
    my above ground pool is only two years old.
    i pulled the pump out of storage for the winter and it is very noisy its sounds it doesn't sound like its coming from the motor itself but some where closer to where it moves the water.
    i had it running for about 3 hours last night and it didn't get hot, its just made a ton of noise, its seems able to push the water as it always did.
    im think i need a new one unless i can easily troubleshoot and fix this one.
    should i even bother or just get a new one? if so what should i get. i have a 12x24x52" above ground pool.
    7.5K gallon 12x24 AG pool, 2-spd 1.5hp running on low, high for vacuuming; cartridge filter PF: 16
    Default Re: new pump?
    What kind of noise? Screech, like bad bearings? Or it's normal noise but just louder?
    Apr 2012
    New Jersey, USA
    kind of but not too sqeally, more like it isn't running smoothly, almost sounds of balance, like maybe the propeller is hitting the containment wall or the bearings aren't rotating smoothly. normally the pump is pretty quiet, but when i turned it one it is just very noisy, it definitely sounds like something is wrong with it and i shouldn't run it.
    Apr 2012
    New Jersey, USA
    i opened it up and it looks like the impeller is getting damaged from a wobbly shaft.
    i guess im buying a new pump.
    i have a proline cartridge filter it currently has a 75sf cartridge in it rated for 75gpm max flow and 30psi max pressure. any recommendations for a new pump? i prefer a 2 speed for vacuuming and i only have a 120v line at the pool.
    I can't help you with the pump/filter match, but I'm sure that Pooldoc, Mark (mas985), or one of the other equipment folks will be by shortly and should be able to help.
    mas985's Avatar
    Pleasanton, CA
    What was the original pump model #? One option would be to just replace the motor if you are satisfied with the performance and the wet end is still in good condition. If not then given the size of your filter, I would go with the smallest AG two speed which is the Pentair Dynamo 3/4 HP. It will probably be less powerful than your last pump but your filter may survive longer because of it. BTW, do use a manual vacuum or automatic?
    Mark
