Thread: Should I be concerned about Sodium level
    May 2012
    Texas
    Default Should I be concerned about Sodium level
    I'm using clorox bleach in my pool and was wondering if I should be concerned with the sodium level rising over time? Does the sodium cause any corrosion of pool equipment or will it cause the the water to become cloudy? Thanks. I have been using bleach for a year now.
    Default Re: Should I be concerned about Sodium level
    Hi Bassinbob,
    You don't need to worry about the sodium level rising from bleach use. Many people add salt to their pools just because they like the "feel" of the water, and the amount they add is hundreds of times greater than what you'll ever get with using bleach. It will not cause the water to become cloudy. In fact, as far as chlorine sources go, bleach is probably the most efficient...it adds chlorine which you need, minute amounts of salt which is actually good, and nothing else--no calcium, no CYA, no acid, etc to have to compensate for. I use bleach in my pool, too.
  1. Slow leak...should I be concerned?
    By JimK in forum In-Ground Pool Construction and Repair
    Last Post: 05-15-2013, 11:15 PM
  2. concerned about TA and CYA level
    By cleanteeth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2010, 08:43 PM
  3. Should I be concerned?
    By steveinaz in forum In-Ground Pool Construction and Repair
    Last Post: 03-05-2007, 01:54 PM
  4. Is sodium bicarbonate same as sodium carbonate?
    By mshumack in forum Dealing with Alkalinity and Calcium
    Last Post: 09-18-2006, 08:52 PM
  5. Concerned about cleaner
    By mohawk in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-30-2006, 01:23 PM
