Thread: Household Chemical for hardness
    May 2012
    New Jersey
    Default Household Chemical for hardness
    Is there a household chemical I can use to increase water hardness?
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Household Chemical for hardness
    calcium chloride. Used as a deicer and in making pickles and Tofu. Usually available in 50 lb bags. Tetra is a good brand for pool use, btw. Either the dihydrate or the anhydrous is ok to use.
    You're in NJ -- a very high proportion of pools in the North East have vinyl liners.
    If YOUR pool has a liner, you don't NEED calcium hardness, from any source! Pool stores just like to sell it to everybody, even though only concrete pools need it!
    May 2012
    WA
    If you have a heat pump do you have to be concerned? We have a vinyl lined pool with low calcium
    With high calcium, yes. With low calcium, no.
    May 2012
    WA
    Thanks PoolDoc! I won't worry about raising the levels.
    doughboy 24x24 AG round 16,100 gal with 3.5 and 6.5 deep end. Doughboy sand filter. Doughboy 1 hp pump. Tropi-cal 75k btu heat pump.
  1. 6% household bleach equivalent to lithium hypochoride granular?
    By magnus in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-24-2013, 10:51 AM
  2. What is hardness?
    By jerome in forum Dealing with Alkalinity and Calcium
    Last Post: 05-08-2012, 12:45 PM
  3. Hardness
    By Lil Bit in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-16-2006, 10:25 AM
  4. Household bleach to shock?
    By Rsnyder in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-16-2006, 02:51 PM
  5. Can I use household bleach for chlorine?
    By dianam in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-14-2006, 08:18 PM
