Sand Filter - Alive?
This is my 1st pool and I constructed it myself with a lot of tips from this forum. Now I need to understand, if what I have is operating normally.
What I have:
18'x36' IG Vinyl pool - 2nd season
Individual 1.5" Tigerflex lines to 1 drain; 1 skimmer; and 2 returns
Pump located 12 feet from pool and all piped 2" PVC in pump house.
30" Sand Filter PENTAIR TAGELUS TA100D w/2in 6-way valve
1hp Sta-Rite Max-Glass II
Aqua-rite Chlorine generator
Polaris 360 pool cleaner without booster
When I turn the pump on/off, I notice that my fiberglass sand filter tank visibly shrinks and expands. It's as if it were breathing! When turning the pump on, I can see the top of the filter rise about 1/4" to 1/2". I know that the pressure from the pump causes this but, I'm worried about my sand filter exploding if this is not normal.
My pressure (even just after backwashing and all strainers clean) sits at about 25psi. With the pressure side cleaner attached it jumps to 30 to 35 psi. When I remove the eyeballs from the 2 returns to unrestrict the flow as much as possible, the pressure drops to about 15 to 20 psi.
Are my operating presssures OK? Is a breathing sand filter normal?
Thanks in advance for your feedback.
- You may not post replies
- You may not edit your posts
Forum Rules
