Results 1 to 10 of 10
Thread: How to fix a plumbing leak?
    Sep 2011
    Default How to fix a plumbing leak?
    Image11.jpgImage10.jpgI hired a leak detection company who, after 4 hours of testing, put a mark on my deck and said "Dig here you'll find the leak". Sure enough there it was but almost completely embedded in gunite. I have been chipping away slow and carefully so as not to damage other pipes or fittings. As the picture shows the PVC pipe is bulging and is not properly connected to the fitting and it leaks badly. Eventually I will get the gunite cleared all the way around it so I can execute a repair. That’s my problem, how to repair it? The way the fittings are so interconnected I can’t take it apart and reassemble it. My thought is repairing it with epoxy putty. Any thoughts would be appreciated. Thanks in advance.
    Sep 2011
    Default Re: How to fix a plumbing leak?
    Image14.jpg It just occurred to me that I should circle the problem area.
    Sep 2011
    I haven't heard from anyone but here are a couple more pictures. I was able to chip gunite away and expose the PVC plumbing involved. The arrow is pointing to where the leak is. Now I need an effective method to patch it, hopefully permanently. PLEASE, I need suggestions.
    Sep 2011
    Thank you Watermom. The good news is, I measured the gallons being lost thru that defective fitting and it is very close, actually more, than the amount I estimated was being lost from the pool. If I find a reasonable method to patch it I will install an access plate in the concrete so I can keep an eye on it.
    Scottsdale, Arizona
    Is that a trap ? If so , can you cut it out and install a smaller one? Or just a straight piece of PVC?
    Sep 2011
    Not a trap. What you are looking at is a mixer assembly with pressure air from one 2" line and water from another 2" line. The other side of that assembly goes thru the pool wall. It can't be touched without causing severe damage. I have managed to stop the leak with a temporary fix. I wrapped the affected area with a 1/2" rubber tape I found in the plumbing dept at Lowes and put a couple of hose clamps on it. We used the pool yesterday and not a drop of water leaked. When I find a similar, but wider, rubber tape I will redo it and call it good.
    Jun 2011
    In the Sticks near Houston, TX
    What does that flex pvc go to?
    ~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
    Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
    Sep 2011
    Quote Originally Posted by TheGoose View Post
    There are 18 mixer/jet assemblies in the pool fed by a 2 HP water pump and an air blower.
    Sep 2011
    I think my latest effort will be a permanent repair. I located a heavy 2" wide rubber tape that is actually made for insulating and waterproofing electrical splices and is made by 3M. It is very similar to the 1" rubber tape I had already installed but didn't have 100% confidence in because it only lapped a 1/2" each side of the leak. I left the 1" in place since it has worked fine for a couple of weeks and put the heavier 2" on top of it. I was able to stretch it to a very tight wrap. After putting the hose clamps back in place it is likely stronger now than the pipe it repairs. Next I will reinstall the jets and run the air blower to check everything under pressure. After passing that final test I will wrap the hose clamps and fill the hole.
  1. Question about plumbing
    By phikappa in forum In-Ground Pool Construction and Repair
    Last Post: 06-07-2013, 11:59 AM
  2. PVC plumbing
    By ckmoreau in forum Above-Ground Pool Construction & Repair
    Last Post: 05-30-2013, 02:44 PM
  3. Hard plumbing
    By msummers in forum Above-Ground Pool Construction & Repair
    Last Post: 06-28-2011, 07:55 PM
  4. Plumbing config
    By mmcguire in forum In-Ground Pool Construction and Repair
    Last Post: 10-08-2006, 09:02 PM
  5. Problems with new plumbing
    By lacosh in forum In-Ground Pool Construction and Repair
    Last Post: 06-28-2006, 04:22 PM
