Re: First test results in and I think I am OK, right?
To save on your reagents, use the 10ml sample instead of the 25ml. Readings within 0.5ppm are good enough.
If you have a CC reading greater than 0.5, you need to shock your pool. (CC is Combined Chloromines. Basically, this means chlorine that is engaged in metabolizing something like algae, bacteria, etc. It gives chlorine its characteristic odor and can irritate eyes. The best way to get rid of it is to increase your FC (Free Chlorine), the good stuff. The ideal level of CC is 0.) So, with a CYA reading of 32 (not sure how you got 32??), the shock level for your pool would be 15ppm. You need to keep your chlorine at shock level until you can go from sundown one evening to within two hours or sunrise the next day without losing more than 1ppm of chlorine and without having more than 0.5ppm of CC. (By the way -- you don't want to use a SWCG to shock a pool. If you truly do have that much of a CC reading and need to shock, turn the SWCG off and just use bleach. This will increase the life of your cell.)
OR -- maybe you don't really have a CC reading of 1.6. You might want to try that test again and report back.
Regarding dippers full of powder --- you don't need to use 2. If one scoop turns it pink, that is all you need. No need to use more powder than necessary.
Lastly, the stabilizer is OK.
You can use dry acid (PH Down) if you prefer to use that instead of muriatic acid.
